how much Deg. advance timing can you get before having to alter dizzy?
I need around 19 deg. advance for my cam. PYRstage3. And also, whats the max deg. you can get from advancing your dizzy on 100 octain.
d16a6 crx si motor in a 92 obd1 DX hatch.
you advanced your cam 19 degrees? or you want to advance distributor timing 3 degrees? if you alter cam timing your going to have to counter adjust (if that makes sense) the distributor timing. thats as much help as i can give with a question like that.
Your topic confused me. I thought u were referring to cam timing?? If its cam timing then i believe the max is 10 degrees advance and 10 retard. Once u adjust the cam timing then distributor must be readjusted (SOHC motors). But if u are referring to ignition timing (which is what i think ur talking about) then 19 degrees advanced can be done. What do u mean "altering the dizzy"? About ur octane question , i really wouldnt know, i guess u could just go out and get some 100 and find out for urself.
