FPR and return line question
I have an aeromotive fpr with the an6 return fitting.. What earls or aeroquip fittings do I need to adapt the an6 fitting to the stock return line on a 89' crx dx.. Thanks
Come on.. If I knew the size of the return line I could find the parts out.. Does anyone know the size of the stock return line hose..
im pretty sure its 3/8 or -6.the -6 means its 6 1/16 id or 3/8th inch.i just installed my aem fuel rail and fpr.it had a 3/8 brass fitting for the return.the stock hose slipped onto it.if you use a -6 braided line off the fpr.you will need to find where the stock hose ends.then use a hose clamp on the pipe.or you could use a union fitting to splice into the stock rubber hose.
edit.scratch that.i just measured the piece i trimmed off.its 7mm hose on the stock return line.or .275 inch.
Dunc
Jun 18, 2006 09:30 PM
