Gear Ratio for ITR's
Old Oct 22, 2003 | 10:34 AM
JDM CTR EK's Avatar
Default Gear Ratio for ITR's
Anyone know the Gear Ratio's for the USDM ITR tranny vs. the JDM ITR tranny. Also the difference between the JDM ITR 96 Spec tranny vs. the 98 spec tranny. Please help!
Old Oct 22, 2003 | 10:42 AM
yellow blur's Avatar
Default Re: Gear Ratio for ITR's (JDM CTR EK)
JDM 98 ITR Tranny / S80
1st. 3.230
2nd. 2.105
3rd. 1.458
4th. 1.034
5th. 0.787
Reverse 3.000
Final Drive 4.785
USDM ITR + JDM ITR '96 Spec + JDM CTR '98 Spec
Y21/S80
1st. 3.230
2nd. 2.105
3rd. 1.458
4th. 1.107
5th. 0.848
Reverse 3.000
Final Drive 4.400
Noted differences are marked in BOLD.
Ed
Old Oct 22, 2003 | 11:06 AM
Downey's Avatar
Default Re: Gear Ratio for ITR's (yellow blur)
what he said.
Old Oct 22, 2003 | 11:42 AM
JDM CTR EK's Avatar
Default Re: Gear Ratio for ITR's (Downey)
Ok Great! Thanks Guys!
Now New Question!
I have a JDM ITR '98 Spec Tranny in my car. My 3rd gear is grinding. (Came like that with the swap) Can I just change it with a '98 spec USDM 3rd?
Old Oct 22, 2003 | 11:46 AM
Most likely your syncro, and not the actual gear.
Old Oct 22, 2003 | 11:57 AM
JDM CTR EK's Avatar
Any idea how much that is?
Old Oct 22, 2003 | 12:08 PM
Ask D. He just bought a butt load of tranny parts. He should know.
Old Oct 22, 2003 | 12:33 PM
MissMyHonda's Avatar
Since you're taking apart the tranny, I would HIGHLY reccomend swapping USDM ITR 4th ~$100(and if you want 5th)...
Old Oct 22, 2003 | 01:31 PM
JDM CTR EK's Avatar
Default Re: (JoesTypeS)
You saying I should swap the 4th gear too? I just want my 3rd to stop grinding. Only thing I need to replace is the syncro right?
Old Oct 22, 2003 | 02:12 PM
Yeah if you just want 3rd to stop grinding...however if you do any highway/drag racing the USDM ITR 4th will help you out a TON. Anyway here are the part #s
Sleeve Set, SYNCHRONIZER 3-4: 23623-P21-315
If you want USDM ITR 4th:
Gear Mainshaft 4th: 23451-P80-000
Gear CounterShaft 4th: 23481-P80-000
Old Oct 22, 2003 | 07:51 PM
JDM CTR EK's Avatar
^^ thanks for the part number. As far as the 4th gear I'll do some research on it.
Old Oct 22, 2003 | 07:59 PM
I think that 4th gear switch is the 2nd best mod for the money I ever did
JDM_Risa
Jan 17, 2006 10:09 PM
realis9
Aug 3, 2005 07:38 AM
euclid
May 3, 2003 12:21 PM
JMendez
Jan 16, 2002 08:03 AM
