Front lower tie bar and JDM 4-1?
I just found a Neuspeed front lower tie bar someone has apparently left in my garage over a year ago. I have a 93 Si with a GS-R... I'm wondering if this tie bar will clear my JDM 4-1 header. I searched, found nothing. Just wondering if anyone has the same setup. Thanks!
It should clear it but the neuspeed bar hangs really low. The good thing is, if you scrape, you will scrape the bar before the header. I have an ITR front lower bar and it's perfect, it bends over the exhaust instead of under.
From: Toronto, Canada currently residing in ATL, GA, USA
I have a DC JDm header which hangs lower then the OEM JDm ITR header and it rests on my Neuspeed bar slightly.
You should haven o problems with clearance.
Well, I tried to put the bar on.. it does not clear the header.
The little skid plate welded to the flange is what gets in the way. I don't think I want to cut this off since if I did come across some high ground, it would rip the flange off.
Oh well.
Oh well.
akhom
Oct 12, 2004 04:12 PM
itr98spec
Apr 2, 2003 09:57 PM
, hop into the garage and give it a go
to reporting usefull stuff
