2 questions
Old Oct 21, 2003 | 09:17 PM
IWearMyKswiss's Avatar
New User
Default 2 questions
1. how can you tell if a tranny is a GSR tranny or not?
2. are 99-00 SI axles the same as Integra LS axles,..orrrr can i use 99-00 SI axles for my LS motor which is in my 97 hatch
Old Oct 21, 2003 | 09:39 PM
New User
Default Re: 2 questions (WiDeBoDyEK)
sorry to bump so quickly but im in need of the answers with the quickness
Old Oct 22, 2003 | 09:22 AM
New User
bump for the day crew
Old Oct 22, 2003 | 09:43 AM
degooser's Avatar
is there a serial number on the tranny somewhere....
Old Oct 22, 2003 | 09:45 AM
degooser's Avatar
Default Re: 2 questions (degooser)
if i remember correctly my girls jdm gsr's tranny says s80......right next to the engine code...
Old Oct 22, 2003 | 09:47 AM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser &raquo;</TD></TR><TR><TD CLASS="quote">if i remember correctly my girls jdm gsr's tranny says s80......right next to the engine code...</TD></TR></TABLE>
yea i got that part,...thanks for the help
now anyone got the asnwer to my second question?
Old Oct 22, 2003 | 09:50 AM
Kalokohan's Avatar
New User
I think your si axles will work....I believe you can use any set of axles as long as the care it came out of was equipped with a b-series motor from the factory. I'm not totally sure about this but something in my head says it will work. You can always match up the part numbers.
Old Oct 22, 2003 | 01:01 PM
New User
Default Re: 2 questions (Kalokohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan &raquo;</TD></TR><TR><TD CLASS="quote">I think your si axles will work....I believe you can use any set of axles as long as the care it came out of was equipped with a b-series motor from the factory. I'm not totally sure about this but something in my head says it will work. You can always match up the part numbers.</TD></TR></TABLE>
thanks for the info,..can anyone back up his info?
Old Oct 22, 2003 | 01:07 PM
Dancing is Forbidden's Avatar
there really is no way, as far as i know unless the VIN plate is still on the tranny, to tell if it is an ls or gsr. they are both stamped s80. all 94+ USDM axles (b series) are the same.
Old Oct 22, 2003 | 01:14 PM
pennies_hatchie's Avatar
yes..
as long as the axles are for any B-series HYDRO manual tranny...it'll work..
gsr, si, itr, ctr, ls, or b18b, b18c1, b18c5, b16a sir2, b16a2..
Old Oct 22, 2003 | 01:42 PM
New User
Default Re: 2 questions (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">there really is no way, as far as i know unless the VIN plate is still on the tranny, to tell if it is an ls or gsr. they are both stamped s80. all 94+ USDM axles (b series) are the same.</TD></TR></TABLE>
okay so both LS and GSR trannys are stamped s80? hmmm how the hell am i suppose to figure out if my friend has a GSR or LS tranny then
oh and thanks guys about the info for the axles ,..i appreciate it
jayhelladum
Sep 25, 2008 09:27 AM
90 civic hb
Jul 22, 2007 06:01 PM
psycho_civic
Aug 5, 2004 06:03 PM
