2 questions
2 questions
1. how can you tell if a tranny is a GSR tranny or not?
2. are 99-00 SI axles the same as Integra LS axles,..orrrr can i use 99-00 SI axles for my LS motor which is in my 97 hatch
Re: 2 questions (degooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">if i remember correctly my girls jdm gsr's tranny says s80......right next to the engine code...</TD></TR></TABLE>
yea i got that part,...thanks for the help
now anyone got the asnwer to my second question?
Re: 2 questions (WiDeBoDyEK)
I think your si axles will work....I believe you can use any set of axles as long as the care it came out of was equipped with a b-series motor from the factory. I'm not totally sure about this but something in my head says it will work. You can always match up the part numbers.
Re: 2 questions (Kalokohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan »</TD></TR><TR><TD CLASS="quote">I think your si axles will work....I believe you can use any set of axles as long as the care it came out of was equipped with a b-series motor from the factory. I'm not totally sure about this but something in my head says it will work. You can always match up the part numbers.</TD></TR></TABLE>
thanks for the info,..can anyone back up his info?
there really is no way, as far as i know unless the VIN plate is still on the tranny, to tell if it is an ls or gsr. they are both stamped s80. all 94+ USDM axles (b series) are the same.
yes..
as long as the axles are for any B-series HYDRO manual tranny...it'll work..
gsr, si, itr, ctr, ls, or b18b, b18c1, b18c5, b16a sir2, b16a2..
Re: 2 questions (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">there really is no way, as far as i know unless the VIN plate is still on the tranny, to tell if it is an ls or gsr. they are both stamped s80. all 94+ USDM axles (b series) are the same.</TD></TR></TABLE>
okay so both LS and GSR trannys are stamped s80? hmmm how the hell am i suppose to figure out if my friend has a GSR or LS tranny then
oh and thanks guys about the info for the axles ,..i appreciate it
psycho_civic
08-05-2004 06:03 PM
