wrx misfire @ 5k rpm
Old Oct 21, 2003 | 07:24 PM
Boltz's Avatar
Default wrx misfire @ 5k rpm
tia. should i uprgrade the plugs? everything is stock except intake and turboxs chip set on stage 1. the CEL flashes sometimes while getting on the throttle@ around 5k and the car feels like it is misfiring, there is a mad delay, running about .1 kpa of boost (around 15psi).... any advice is appriciated
justin
Old Oct 21, 2003 | 07:32 PM
jarel's Avatar
Default Re: wrx misfire @ 5k rpm (BoostRotter)
I'd say put back on the stock intake. Aftermarket intakes on stock Wrx's aren't that good. No gains and messes with the MAF sensor and swamps it.
Old Oct 21, 2003 | 07:34 PM
Boltz's Avatar
Default Re: wrx misfire @ 5k rpm (chyknees)
you honestly think that would have anything to do with it?
Old Oct 21, 2003 | 07:37 PM
jarel's Avatar
search http://www.nasioc.com . You should find an answer there. But i've heard that there are problems with putting some aftermarket intakes on. But ya...I think that that is the problem.
Old Oct 21, 2003 | 07:38 PM
Boltz's Avatar
it never used to do it when it only had the intake on.... only started doing it once the turbo xs chip was installed
Old Oct 21, 2003 | 07:49 PM
jinxproof99's Avatar
New User
email nathan @ turboxs or give them a call. he'll clear it up for you quick.
Old Oct 21, 2003 | 07:56 PM
Boltz's Avatar
Default Re: wrx misfire @ 5k rpm (jinxproof99)
thx jinx
bonesx0x2x4x
Apr 5, 2011 07:35 PM
oovvutt
91
Nov 26, 2009 09:40 AM
Yosshaa
Honda S2000
Apr 23, 2007 10:02 AM
ciRcuitJerk
12
Mar 16, 2003 06:12 AM
BlackGSR
Aug 4, 2002 06:03 PM
