Wiseco high comp. Pistons CR?
I just received my Wiseco pistons. It says on the box the dome volume is +5cc. Is this the same as the combustion chamber volume? If it is, I used the comp. calculator and it says I have a 11.2:1 with a ls/vtec (b16 head). If this is correct, it's perfect for my setup. Can we say NA?......75 shot nitrous assisted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specie »</TD></TR><TR><TD CLASS="quote">I just received my Wiseco pistons. It says on the box the dome volume is +5cc. Is this the same as the combustion chamber volume? </TD></TR></TABLE>
Dome volume is not the same as combustion chamber volume. More piston dome volume will give you more compression. More combustion chamber volume will give you less compression.
You're right. I was looking at the wrong part of the comp. calc. when I was typing it.
I guess it's 11.2:1 then.
Thanks.
Thanks.
RealStreet
Performance
61
Nov 25, 2011 08:54 AM
trooper0641
12
May 10, 2004 09:41 PM
