Engine mounts shot. Where to go for replacements?
Old Oct 21, 2003 | 11:28 AM
Johnyquest's Avatar
Default Engine mounts shot. Where to go for replacements?
Ever since my turbo install, my stock d16z6 mounts in my 95 civic are shot. The motor moves what has to be 6" in each direction when driving (so hard to drive) and even an inch or so when revved in neutral off idle. So, I definatley need some new mounts. Honda wants like $500 dollars for the set. What a rip. I saw the mounts on http://www.jimfab.com and the prices are good-- but the ones he has listed next to 92-00 civic totally don't look like they fit (the mounts are 90* off?). I'm confused. Where can I go for some good, solid, strong mounts to replace my stockies? Any help is appreciated!
Old Oct 21, 2003 | 11:59 AM
Jmunk's Avatar
Get energy suspension motor mount inserts. They work on borken mounts. Cheap too.
Old Oct 21, 2003 | 10:58 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Jmunk)
ES inserts, you really only need the lower rear insert. WHich BTW is a PITA to install!
Old Oct 29, 2003 | 04:03 PM
Johnyquest's Avatar
Default Re: (Mista Bone)
Well, I got the mount inserts, energy suspension, 42$ shipped. They came today. I'm going to try to tackle them either this week or next. I can't remember if i took the rear mount off when I did the clutch or not... How hard is it?
Old Oct 30, 2003 | 12:51 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Johnyquest)
remove the rear bracket, intake manifold brace, then you can get at the rear rubber mount.
You may need to clearance the inserts to fit.
The good news, once the rear inserts are in, you never have to worry about then again. Atleast I haven't!
smokey.23
22
Mar 24, 2009 09:01 PM
clem kevin
May 1, 2008 06:57 PM
white_db8
May 26, 2007 09:34 AM
BMo Tuning
Sep 20, 2005 09:28 PM
Drew Peacock
Dec 3, 2004 03:31 PM
