LS block on B20 crank.
its exact same crank should work fine 89.00 stroke on both only different between ls and b20 block is the bore 81mm vs 84mm both use a 137.00 rod with exact same r/s ratio
Don't worry about the rod to stroke ratio! Sure, it's a little worse than a B18C1 and worse than a B16, but just because the rod ratio isn't that great doesn't mean that it's going to break down on you in 5000 miles if you rev it high. There are a bunch of guys on here spinning LS motors to 9000+ without incident. Balance the motor properly and have it assembled properly and you'll have no issues.
