LS block on B20 crank.
Old Oct 21, 2003 | 10:47 AM
Hoosier Daddy's Avatar
Default LS block on B20 crank.
Will it work, or is the rod stroke ratio different? Thanks
Old Oct 21, 2003 | 11:05 AM
b18bturbo's Avatar
Default Re: LS block on B20 crank. (Boost Creep)
its exact same crank should work fine 89.00 stroke on both only different between ls and b20 block is the bore 81mm vs 84mm both use a 137.00 rod with exact same r/s ratio
Old Oct 21, 2003 | 11:26 AM
Default Re: LS block on B20 crank. (b18bturbo)
Thank you sir, wasn't sure about the r/s ratio
Wasn't really up to swapping cranks
Old Oct 21, 2003 | 12:29 PM
InfamousRS's Avatar
LS and B20 cranks are the same....The only thing that differs between the 2 motors is the bore diameter. 81mm vs. 84mm.
Old Oct 21, 2003 | 01:15 PM
hybridb18's Avatar
Default Re: LS block on B20 crank. (InfamousRS)
crank and rods same part numbers
Old Oct 21, 2003 | 01:26 PM
boosted92's Avatar
Default Re: LS block on B20 crank. (hybridb18)
Don't worry about the rod to stroke ratio! Sure, it's a little worse than a B18C1 and worse than a B16, but just because the rod ratio isn't that great doesn't mean that it's going to break down on you in 5000 miles if you rev it high. There are a bunch of guys on here spinning LS motors to 9000+ without incident. Balance the motor properly and have it assembled properly and you'll have no issues.
Old Oct 21, 2003 | 02:08 PM
Default Re: LS block on B20 crank. (boosted92)
I'm not looking to rev any higher than the stock limit.
thegeezerkid
Jun 8, 2009 01:33 PM
Henry HA
Feb 18, 2003 07:48 PM
LsPower
Jan 17, 2003 11:01 AM
Kamin
Dec 1, 2002 11:51 AM
pissedoffsol
Nov 4, 2001 09:48 PM
