n00bmech. question about o2 senor...
Old Oct 21, 2003 | 10:28 AM
98cwitr's Avatar
Default n00b mech. question about o2 sensor...
it's ok to spray WD-40 on your o2 sensor to loosen it up so that i can get it out? its on pretty d*mn tight.
Old Oct 21, 2003 | 11:00 AM
Dr. EKology's Avatar
Default Re: n00b mech. question about o2 sensor... (98cwitr)
Yes, I had to do this aswell. Just make sure you let it evaporate before you start the car. I let mine sit until the stain dissapeared, then I cranked her up. If you don't wait, there is risk of fire, but it will definately start to smoke.
Old Oct 21, 2003 | 11:06 AM
Smitdog's Avatar
Default Re: n00b mech. question about o2 sensor... (EVIL_EKology)
Not a good idea to gert brake cleaner or anything on that sensor. No need to chance something that is so much $$$$$.
Old Oct 21, 2003 | 11:11 AM
Default Re: n00b mech. question about o2 sensor... (Smitdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smitdog &raquo;</TD></TR><TR><TD CLASS="quote">Not a good idea to gert brake cleaner or anything on that sensor. No need to chance something that is so much $$$$$.</TD></TR></TABLE>
He's only spraying it where the O2 meets the exhaust manifold. I think its safe, thats what I used to remove mine, along with a massive adjustable wrench and a 18" pipe. He isn't getting it onto the sensor itself, just on the threads.
Old Oct 21, 2003 | 11:16 AM
splitime's Avatar
Drive the car around some, heat up the header. Do this after you hit it earlier with WD40 or even better PB-Blaster. Once its warmed up, try to undo it. The heat will expand the o2 bung just a bit and allow for a bit of an easier wrench job.
Old Oct 21, 2003 | 11:18 AM
Chris N's Avatar
Default Re: n00b mech. question about o2 sensor... (splitime)
Just jump on the wrench, scream, swear and sweat, or use a breaker bar, or go to the gym and make some muscles.
Or do what dave said.
Old Oct 21, 2003 | 11:46 AM
Default Re: n00b mech. question about o2 sensor... (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">Just jump on the wrench, scream, swear and sweat, or use a breaker bar, or go to the gym and make some muscles.
...just make sure that you don't strip that sum' bitch!!
Old Oct 21, 2003 | 12:25 PM
98cwitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology &raquo;</TD></TR><TR><TD CLASS="quote">
...just make sure that you don't strip that sum' bitch!!</TD></TR></TABLE> thats what im worried about...i think i just spray it very lightly.
Old Oct 21, 2003 | 12:27 PM
98cwitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Drive the car around some, heat up the header. Do this after you hit it earlier with WD40 or even better PB-Blaster. Once its warmed up, try to undo it. The heat will expand the o2 bung just a bit and allow for a bit of an easier wrench job.</TD></TR></TABLE> and flames engulf my cat
Old Oct 21, 2003 | 12:49 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote"> and flames engulf my cat </TD></TR></TABLE>
pic?
Old Oct 21, 2003 | 01:00 PM
Chris N's Avatar
Yea, right.
Notice he said 'you hit it EARLIER with WD40'. Not three seconds before you drive around or after you drive around. Reading comprehension sucks on here.
x100
Old Oct 22, 2003 | 08:40 AM
98cwitr's Avatar
Yea, right.
x100</TD></TR></TABLE> i was just messing around im going to try it...WHENEVER MY CAT GETS HERE! i still gotta mail my money order to Dave @ SMSP. (hes one busy man...ill give him that, but does great work so i hear). header will be here friday
93CamaroLT1
Oct 12, 2008 06:53 AM
Ess0n23
Aug 10, 2007 10:01 PM
Fook_me_honda
Jul 6, 2004 01:50 PM
