battery light on on summer !off on winter!
Old Sep 3, 2001 | 10:56 AM
vimcortes's Avatar
New User
Default battery light on on summer !off on winter!
Why is it that ,I have replace three alternators,to fix this problem and it seems
to be a problem. The first alternator was a generic,second one was a track auto
alternator's the third one and current one on is an Bosh, I just bouht one from
honda and I'm afraid to put it and damage it.
I can tell the difference when I drive the car and the light is on !
Plaese Help it a 90 CRX.1.5
Old Sep 3, 2001 | 11:44 AM
fixhondas's Avatar
Default Re: battery light on on summer !off on winter! (vimcortes)
get a honda alternator
Old Sep 3, 2001 | 07:16 PM
nawoj's Avatar
Default Re: battery light on on summer !off on winter! (fixhondas)
i had mine replaced not too long ago
and since then it has been humming, almost whirring [i tell riceboys its a supercharger!]
it works fine but the buzzing gets annoying,
not sure what the brand was but im not sure if its the alternator itself or the belt.
Old Sep 3, 2001 | 08:36 PM
PrjR Rex's Avatar
New User
That would either be the belt or the actual bearing. Anyways if the car has eaten three so far LOOK into fixing something else. They dont go out that easy. IF youhave a big stero system, or after market alarm, it could be sucking your battery dry forcing the alternator to over work, as well as many other components of the electrical system. Maybe a bad ground, maybe the battery cables are gummed up on the inside where you cant see untill you cut them apart. But I seriously doubt its an alternator. I have a stock japanese alternator from 90, haha. (probably gonna go out next week now). I also work at a local auto store and was trained mainly on charging system components and failures. Check something else out, first. Or have a honda qualified tech check it out and save you money in the long run.
89edcivic
Sep 26, 2009 02:38 PM
sixgunsound
Jun 7, 2009 05:45 PM
haywyre
Oct 9, 2008 12:27 PM
da9pwnsu
Jan 19, 2007 12:12 PM
fe519
Sep 23, 2003 03:25 AM
