just a point of advice (VTEC solonoid related)
Old Oct 21, 2003 | 09:39 AM
SuperJay's Avatar
Default just a point of advice (VTEC solonoid related)
Don't overtighten the VTEC solonoid to the head. I went through about 5 gaskets before I realized that the reason I kept blowing them is because I was tightenin it too much. The torque spec for it is 8.7 ft.lbs. Just thought I would share this info.
Old Oct 21, 2003 | 11:25 AM
bossman032's Avatar
Default Re: just a point of advice (SuperJay)
hehe dang bro.
yea we should all be aware off that..
Old Oct 21, 2003 | 03:51 PM
revhigh89's Avatar
Default Re: just a point of advice (bossman032)
thanks man, thats good tip
Old Oct 21, 2003 | 04:02 PM
civisaurusrex's Avatar
completely unrelated, but make sure you read the right line in the service manuals too. like the cam gear bolt torques to something like 37 ft. lbs on the d16z6. of course the next line down is the crank pulley bolt at well over a hundred... needless to saym, i had to take the cam to the machine shop to get the rest of the bolt drilled out
Old Oct 22, 2003 | 12:47 PM
SuperJay's Avatar
Default Re: (civisaurusrex)
oh yeah, another thing I found out. If you notice that when your driving and you come to a stop, the idle drops really low and then bounces back up to 750-ish, make sure you have the check valve that runs to your dash pot "on" and "in the right position". this made a huge diff with my idle. I had the check valve backwards.
dunkd
Feb 17, 2021 03:11 PM
ChrisEK9
15
Jun 7, 2010 04:53 PM
pmey
Feb 9, 2009 02:02 PM
luderollin
Feb 23, 2005 06:52 PM
mdt017
Aug 21, 2002 12:40 PM
