help 1988 civic si with b16 engine
Same happened to my engine when i had it swapped, my HICV's (high idle control vavle?) internals were all loose and air was just blowing through it. It is supposed to let a small amount of air through when engine is cold till it gets warm...then when engine is hot it closes up and car drops to 7-800rpm's. It's somewhere around the TB and has coolant running to it. Maybe i'm wrong but that sounds like what what was happening to me.
also make sure all your vac lines are hooked up correctly and check out your throttle body gasket maybe need to replace that and last but not least make sure your throttle cable isnt too tight..hehe
brandonmc
Jul 26, 2011 09:34 AM
Hardedge
May 16, 2009 07:38 PM
