stock engine compression
Old Oct 20, 2003 | 08:36 PM
sloweredcivic's Avatar
Default stock engine compression
Does any one know the stock compression numbers for a d16z6 i have #1. 170 2. 180 3. 170 4. 180 are these numbers good or bad? the motor has sat for about 6 months, we took about a cap of oil and put it in the cylenders to lube the top of the cylenders good or bad idea? well it raised the compression tests to 1. 190 2. 200 3. 195 4. 205 does this make sense to any one else?
Any help would be great thanks
Old Oct 20, 2003 | 09:23 PM
JonGP4's Avatar
Default Re: stock engine compression (sloweredcivic)
yeah i think those numbers are ok, pretty much as long as they all have the same compression the better.. all the oil did was add more compression cuz there was less space in the cylinder.. it might have lubed up the sleeves alittle but not much, the really test is let it warm up then check the compression
puma2132
Feb 8, 2009 02:37 PM
vtec25
Aug 20, 2006 12:28 AM
fastfu
Jun 22, 2004 05:18 PM
builtprelude
Jan 22, 2004 10:49 PM
