My LS comp. numbers....
Healthy numbers there. The main thing to look for when doing a compression check/test is that all numbers are somewhat consistent with only a 5% difference at most between each. When you see one much lower than the others, then you most likely have a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupeMT »</TD></TR><TR><TD CLASS="quote">great numbers only 1psi deviation</TD></TR></TABLE>
Actually it's 6psi deviation
...my D15 with 10:1 compression had 211-215 across the board
