Front brakes acutally klunking...Please read on.....
Old Oct 20, 2003 | 12:11 PM
SL!M's Avatar
Default Front brakes acutally klunking...Please read on.....
My brakes today were smoking bad, not visual but you couls smell it while the car was moving. So i got home and jacked it up becuase he left front was the bad one so I looked at it. For inspection they told me I need a tir rod, so will that be causing the problem? Becuase i checked the caliper and everything is tight, so how come the car is actually klunking when i apply the brake. I dont want to replace the caliper unless its a last resort, what else could it be? Thanks
Old Oct 20, 2003 | 12:22 PM
pdiggitydogg's Avatar
might be just a warped rotor...check that (take the wheel off and free-spin the hub while looking through the rotor (@ the vents) to check for warpage.
Does the pedal pulse when you press it?
Old Oct 20, 2003 | 01:33 PM
Perfectionist's Avatar
Default Re: Front brakes acutally klunking...Please read on..... (mOuse)
A lose tie rod would probably cause the clunk you hear. Other than that, check your upper ball joints.
Old Oct 20, 2003 | 02:41 PM
ruthless013's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">might be just a warped rotor...</TD></TR></TABLE>
Old Oct 20, 2003 | 02:54 PM
JDMlyfestyle's Avatar
I had a similar problem on my old EG and my caliper was siezed.. but id say warped rotor first
Old Oct 20, 2003 | 03:23 PM
madman604's Avatar
repeated clunking? "clunk-clunk-clunk" or one clunk?
Old Oct 20, 2003 | 03:37 PM
Jmunk's Avatar
I'm going with bad tie rod or balljoint for the clunk and a frozen caliper for the smoke.
Old Oct 20, 2003 | 04:03 PM
SL!M's Avatar
It was the tie-rod. thanks guys
JDM_SOHC
Mar 23, 2006 05:11 PM
CWBETB
Apr 26, 2005 11:48 AM
DC 2
Apr 1, 2004 05:27 AM
TegRun
Mar 26, 2004 11:26 AM
Gonzo_SiR
11
Mar 11, 2004 11:48 AM
