Headgasket of choice for stock B18C1???
Old Oct 20, 2003 | 11:44 AM
VTC_CiViC's Avatar
Default Headgasket of choice for stock B18C1???
Inlinepro, Cometic, GReddy, HKS.. so many gaskets to choose from, is there any 1 favorite among you power makers?
Mind you this is for an otherwise stock GSR, looking for a mild output of around 300whp @ say 12-14psi. I figure I'll go with the gasket and ARP hardware along with a T3/T04E 60-trim, so what seems to be the gasket of choice?
Old Oct 20, 2003 | 11:47 AM
hpfsi's Avatar
Default Re: Headgasket of choice for stock B18C1??? (VTC_CiViC)
OEM - nothin' better
ekb18c's Avatar
hmmm how about stock head gasket.
Old Oct 20, 2003 | 11:56 AM
HybridKOOP's Avatar
Default Re: Headgasket of choice for stock B18C1??? (ekb18c)
No reason to use anything but a stock gasket unless you're over 81.5mm
Old Oct 20, 2003 | 12:07 PM
VTC_CiViC's Avatar
Default Re: Headgasket of choice for stock B18C1??? (HybridKOOP)
Well, my intent was to lower the compression a touch
Old Oct 20, 2003 | 12:19 PM
TurboJesse
Guest
Posts: n/a
im using an inline pro 3mm gasket (arp headstuds too) lowers comp. ~1pt
Old Oct 20, 2003 | 01:25 PM
drvfast's Avatar
stock
Old Oct 20, 2003 | 01:49 PM
TurboJesse
Guest
Posts: n/a
Default Re: Headgasket of choice for stock B18C1??? (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">stock </TD></TR></TABLE>
and how will a stock gasket lower compression Like he said he wants one that will lower compression...Inline pro gaskets are high quality
Old Oct 20, 2003 | 01:56 PM
Tofurky's Avatar
Default Re: Headgasket of choice for stock B18C1??? (Mpir3)
Well, technically you are on the East coast... so that means you'll have great luck with the InlinePro headgasket. It will lower you down a full point, to like 8.9:1 and you'll pull 10's & 11's with a stock block.
But if you were on the West Coast.... it'd just never work.
It's a good piece, just make sure to get adjustable cam gears and ARP head studs to go along with it. You'll need to adjust the cam gears because the gasket will throw off timing a bit.
Personally I'd go with a stock HG and enjoy the 10:1 compression, because with such a small turbo(you're running the greddy kit, right?) you'll never see the benefit of running such low compression. Just my $.02...
Old Oct 20, 2003 | 04:13 PM
TurboJesse
Guest
Posts: n/a
Default Re: Headgasket of choice for stock B18C1??? (Tofurky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tofurky &raquo;</TD></TR><TR><TD CLASS="quote">Well, technically you are on the East coast... so that means you'll have great luck with the InlinePro headgasket. It will lower you down a full point, to like 8.9:1 and you'll pull 10's & 11's with a stock block.
East Coast&gt;West Coast Its funny seems like alot of people have sucess with thicker headgaskets on the east coast...not alot of people run them out West?
Old Oct 20, 2003 | 05:54 PM
VTC_CiViC's Avatar
Actually, it's a revhard with a small T3, but that's being changed in time to a T3/T04E hence the desire to drop compression a touch. Thanks
juanb
Jul 7, 2007 07:10 AM
donkiman
Jan 24, 2005 08:10 PM
86si
Jun 25, 2004 12:18 PM
boomslang
Sep 18, 2002 12:48 PM
