Bleeding Air out of Clutch
Old Oct 20, 2003 | 08:40 AM
xerox445's Avatar
Default Bleeding Air out of Clutch
From what i understand you just turn the car off, and pump the pedal and hold it down, while someone opens up the valve on the slave cylender, and that will get the air out...am i going to loose alot of fluid, so i have to get some new fluid?
Old Oct 20, 2003 | 09:04 AM
Foozball26's Avatar
Default Re: Bleeding Air out of Clutch (xerox445)
yup, just make sure you keep topping of the fluid in the reservoir so you don't put more air into it.
Old Oct 20, 2003 | 10:15 AM
monicle's Avatar
pumping the pedal isnt necessary. Just push and hold down the pedal, open the bleeder, close the bleeder, depress and pushdown the pedal again. you can usually do it 2 times before refilling the resivoir.
tbuck23
Apr 3, 2007 01:27 PM
ekim952522000
Jan 8, 2006 04:17 PM
timsch75
Sep 27, 2005 07:46 AM
1SlowSi
Aug 16, 2005 07:24 AM
PatrickGSR94
Mar 10, 2003 11:17 AM
