Brain fade not brake fade. rear brake question
Old Sep 2, 2001 | 06:51 PM
tractoy's Avatar
Default Brain fade not brake fade. rear brake question
When changing the rear pads, do you adjust the threaded rear piston so that it almost engages the brakes. Maybe backed off a half turn. Or do you spin it all the way in and leave it?
Chris
Also,. anyone at Summit on the 7th?
Old Sep 2, 2001 | 11:41 PM
yoshi234's Avatar
I shoot brides
Default Re: Brain fade not brake fade. rear brake question (98type-r)
someone correct me if I did it wrong, but I turned mine all the way in. Once everything was back together, I pumped the brakes till I felt the pads firm up.
-y
Old Sep 3, 2001 | 06:11 AM
nsxtcjr's Avatar
New User
Default Re: Brain fade not brake fade. rear brake question (yoshi234)
Yes, just push it all the way in. When you step on the brakes a couple of times, it will push out up against the pad.
bboylito
Sep 21, 2004 11:05 PM
mickey513
Oct 2, 2003 04:35 AM
AK94GSR
May 30, 2003 01:31 PM
PearlWhiteAccord
Jul 11, 2002 06:09 PM
