cel 20
Old Oct 20, 2003 | 12:13 AM
theslugbug's Avatar
Default cel 20
how do i fix that?? i have 95 hb with b16
Old Oct 20, 2003 | 12:57 AM
MugenB16A2's Avatar
Electrical Load Detector
defective circuit or unplugged / defective sensor
Check your fuses under the dash. I had this occur twice: once on my '97 EK w/B16, and another time on my '00 Si.
Should be a 7.5amp fuse that is blown, it controls your *speed sensor and **alternator.
*Check to see if your speedometer doesn't give any readings, and your odometer shouldn't be turning over either.
**Be careful, becasue your car is relying on your battery only right now. That blown fuse is keeping the alternator from sending back a charge to fill the battery.
Old Oct 20, 2003 | 04:07 PM
theslugbug's Avatar
Default Re: cel 20 (alllgo)
which one would i replace(exact spot)?? is there more than one 7.5 fuse under the dash???? my speedometer works but sometimes flicks up and go crazy. other than that, everything seems to be ok
Civic Racer X 7
13
Jun 1, 2011 04:56 AM
1997civicex
Apr 23, 2009 04:52 PM
EJason
Mar 5, 2009 10:19 AM
_Bug_
13
Feb 22, 2006 07:30 AM
