Crazy Jumping Speedo Needle
Relay? Ehat the hell is that. If the speedo jumps around at a stop (typical for 92-95 civics) then you need a speedometer. If you want to double check do this: use your cruise control- when the needle jumps around and your cruise is working fine- you know for sure it is the speedometer. If your cruise acts crazy then I would suspect the speed sensor.
