Crazy Jumping Speedo Needle
Why does my speedo needle jump up and down sometimes for no reason? Any one else have this happen to them? Thanx
Re: Crazy Jumping Speedo Needle (cj7420)
time for a new speedo
Re: Crazy Jumping Speedo Needle (fixhondas)
speed sensor relay... it's like $80
Re: Crazy Jumping Speedo Needle (MrDX)
Relay? Ehat the hell is that. If the speedo jumps around at a stop (typical for 92-95 civics) then you need a speedometer. If you want to double check do this: use your cruise control- when the needle jumps around and your cruise is working fine- you know for sure it is the speedometer. If your cruise acts crazy then I would suspect the speed sensor.
Speed sensor...ive seen that on my friends. http://images.zeroforum.com/smile/emhammer.gif
Usually at WOT right? and sometimes while driving normal? [Modified by RaceBred, 3:56 PM 9/3/2001] |
Re: Crazy Jumping Speedo Needle (RaceBred)
it happen to me... its the vss sensor... "vehicle speed sensor" unless ur speedo's screwed but i doubt it
Ok thanks "fixhondas"
woo man, like what part of the chicken does the Chicken McNugget come from? woo that blows my freakin mind..... |
