GSR rear brakes in 92 cx questions
Old Oct 19, 2003 | 09:56 PM
LudeHatchH22a's Avatar
Default GSR rear brakes in 92 cx questions
Hey guys,
I have a 92 CX and i just got done doing a gsr rear brake conversion and new pads. Well i have to pump up my brakes to get the rear brakes to work, otherwise just the front works.
please, someone that accutally knows, not just guessing proportions valves, answer. Preferably someone that has done this before.
aslo, i did replace the MC and bled the brakes counless times, it did get a litle better, i just dont know
help
thanks
Old Oct 19, 2003 | 10:04 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: GSR rear brakes in 92 cx questions (LudeHatchH22a)
just keep bleedin the system. and once you think you've bled it enough bleed it some more. i had the same problem when i did the conversion.
Old Oct 19, 2003 | 11:25 PM
LSVtecEK1's Avatar
Default Re: GSR rear brakes in 92 cx questions (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">just keep bleedin the system. and once you think you've bled it enough bleed it some more. i had the same problem when i did the conversion.</TD></TR></TABLE>
yes, exactly what he said, you can even do it while the car is running, and that helps sometimes. The first time i did it, no problem, but i just did the 96' type r suspension the other day and the brakes took countless times bleeding before they began building pressure.
Old Oct 20, 2003 | 12:11 AM
Quik Chris's Avatar
Default Re: GSR rear brakes in 92 cx questions (SmlMtrEK)
word. Be sure to bleed furthest from the MC to the closest, and bleed using a hose on the bleedervalve going into a cup of fluid w/ the hose submerged.
Techy
Jan 22, 2009 08:42 PM
Jdmsoles
Suspension & Brakes
Nov 7, 2008 05:58 PM
EGLUVN
Jun 14, 2007 02:28 PM
LudeHatchH22a
Oct 19, 2003 09:55 PM
