Breaking Axles!!!!
Hmm.... i keep breaking axles i think it is becuase of alot of wheel hop .... but uhmm does anyone else have to beat there axles in threw the side that the tire goes on??? what axles should i be buying GSR or Civic?? i have a 92 hatch check my sig for setup//
with as much power as you are probably making why don't you buy some aftermarket axles, like the driveshaftshop.com. I have a set of there stage 1, they have up to a stage five which are sick.
If the car is lowered a lot, the angle on the axles will make them more prone to breakage. And aftermarket beefy axles would not hurt-with as much money as you have in your setup, you can probably afford some good axles.
