problems with my d16z6 swap
Old Oct 19, 2003 | 08:15 PM
KOOL-AID's Avatar
Default problems with my d16z6 swap
ok i really need some help on this...also i searched this and i couldnt find anything...alright when i try to start the car it doesnt stay on.... the car is getting spark because it turns on for like a second and then nothing....so i was thinking it might be a fuel problem but i could be wrong so what you guys think i tried to see if its throwing any codes but i dont know if i have it hooked up right on a switch so any feed back would be appreciated thanks!!!
Old Oct 19, 2003 | 08:22 PM
rsmotors's Avatar
Default Re: problems with my d16z6 swap (KOOL-AID)
if you are using the stock distributor for the d16z6, it won't start.
you have two choices, modify your crx to fit and calibrate it to fire at the right angle or convert your car to obd1 using a conversion harness so you can run obd1 distributor and ecu
the main point, match the ecu with the distributor
obd0 16 tooth distributor
obd1 and obd2 both 24 tooth distributor
Old Oct 20, 2003 | 01:38 PM
KOOL-AID's Avatar
Default Re: problems with my d16z6 swap (rsmotors)
no im not using the stock dizzy i converted to obd1 but im not sure how to hook up the switch so i could see if there is any codes.....by the way its a kenji harness but i think my problem is that it might not be getting gas what do all of u think
Old Oct 20, 2003 | 02:10 PM
CRX Si's Avatar
sounds like a fuel issue to me... when I forget to turn my fuel cutoff back on it does that...
Old Oct 20, 2003 | 03:00 PM
Doctor CorteZ's Avatar
bad main fuel relay ?
Old Oct 20, 2003 | 07:17 PM
KOOL-AID's Avatar
Default Re: problems with my d16z6 swap (Doctor CorteZ)
where would the main fuel relay be at like on that box thats on the shock tower??
because i know my wiring is right but im going to go back and double check but im positive its right!!
Old Oct 21, 2003 | 01:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOOL-AID &raquo;</TD></TR><TR><TD CLASS="quote">where would the main fuel relay be at like on that box thats on the shock tower??
thats the resistor , MFR is above the hood release.
7rrivera7
May 14, 2014 03:25 AM
almostjdmeg
Nov 11, 2008 01:08 PM
onesikgsr
Jan 29, 2008 08:47 AM
dr_latino999
Jul 25, 2005 06:12 AM
untitled
Aug 5, 2003 05:44 PM
