rev matching
Old Sep 2, 2001 | 04:59 PM
95vtec's Avatar
New User
Default rev matching
lets say im in 3rd at 50 i'm around 3000rpm do i add 1500 to that so i downshift to second and revto 4500 help i don't understand i'm new
Old Sep 2, 2001 | 07:22 PM
Dr Pooface's Avatar
Default Re: rev matching (95vtec)
Just practice alot, you'll know when you do it right.
Old Sep 2, 2001 | 08:11 PM
Warren's Avatar
Wrong-Way Wang
Just blip it. You'll get used to how much you need to blip with a little practice. Make sure that you blip though. Don't hold down the throttle and jam it in gear. This is a beginner mistake that I made when I was first learning. If you blip, and hold the gearlever against the gate for the lower gear, it should slip in when the time is right.
Warren
Old Sep 3, 2001 | 06:24 AM
Cosworth's Avatar
I would suggest that you go buy Best MOTORing International Vol 1. video and watch the footwork to _see_ the process being done. It really helps to see the visual and then practice. The steps are:
1. Clutch in
2. Blip the throttle to desired rpm. (must be quick)
3. Down shift to desired gear
4. Clutch in.
You can practice while the car is parked in the garage. Just keep practicing and you'll get it down in no time. Oh, at first, if you want to rev match before going into a turn, be sure to do so way in advance before the turn. It's no fun not in gear when going through a turn.
Old Sep 3, 2001 | 06:29 AM
DutchITR1689's Avatar
Do you want to double clutch or to "heel and toe"?
suken19
Mar 21, 2006 10:00 AM
skrigz
Mar 6, 2004 01:54 PM
Fraggle
Dec 18, 2003 04:45 PM
dLo GSR-stolen-now-WRX
Nov 28, 2002 10:51 AM
DIRep972
Oct 8, 2001 02:06 PM
