LS oilpan = same as itr oil pan?
Old Oct 19, 2003 | 04:59 PM
Black R's Avatar
25 Year Member
Default LS oilpan = same as itr oil pan?
Will the itr oil pan fit an LS?
I have an ls motor that needs an oilpan, and am thinking of upgrading my stock itr oil pan for a baffled one. If I can use my old itr oilpan on the LS, that would be great.
Old Oct 19, 2003 | 05:36 PM
Russ713's Avatar
dAng!
Default Re: LS oilpan = same as itr oil pan? (Black R)
i don't know if the ITR will work on the LS, but I know the b16 oil pan that I have should fit. I was told that the B16 and LS can share, and the GSR and ITR can share. If you want to verify the info and buy mine, let me know. I'm only 3 hours from you.
Old Oct 19, 2003 | 05:47 PM
migs's Avatar
Default Re: LS oilpan = same as itr oil pan? (Russ713)
It is different.
Old Oct 19, 2003 | 05:48 PM
Dropspeed's Avatar
Ken,
The oil pans will interchange, The oil pump pick up and windage tray will not.
Mattj
Old Oct 19, 2003 | 08:08 PM
migs's Avatar
Default Re: LS oilpan = same as itr oil pan? (Dropspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs &raquo;</TD></TR><TR><TD CLASS="quote">It is different.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">Ken,
Mattj</TD></TR></TABLE>
I knew there was something different. Can anybody else concur?
Old Oct 19, 2003 | 09:59 PM
Black R's Avatar
25 Year Member
.....so is it a go or no?
If I can ghetto-rig it to work, what would be involved?
me = 'tard
-thx
Old Oct 20, 2003 | 12:32 AM
acydphryck's Avatar
uh....i'd stick with the stock LS oilpan...just cuz it's an ITR oil pan doesn't mean it's meant for use with an LS block
Old Oct 20, 2003 | 04:58 AM
00 FBP ItR's Avatar
If i remember correctly...
itr fits on the ls.
the ls doesn't fit on the itr.
Ls oil pans are more shallow, and doesn't clear gsr/itr windage tray/oil pickup.
Old Oct 20, 2003 | 06:19 AM
Dropspeed's Avatar
Default Re: LS oilpan = same as itr oil pan? (00 FBP ItR)
The oil pans are interchangable, Same size, same capacity. The VTEC and NON VTEC oil pump pickups and windage trays are the only difference.
Mattj
Old Oct 20, 2003 | 02:27 PM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">The oil pans are interchangable, Same size, same capacity. The VTEC and NON VTEC oil pump pickups and windage trays are the only difference.
Yes, this is correct. If you change the pan, you should change the pickup as well if you are switching between different motors. Some pickups are different lengths than others.
Old Oct 21, 2003 | 11:53 PM
sgT's Avatar
sgT
No.
P72 pan will fit on all
Non-P72 will NOT fit on P72
Old Oct 22, 2003 | 12:26 AM
R-1303's Avatar
Default Re: LS oilpan = same as itr oil pan? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">
No.
Non-P72 will NOT fit on P72</TD></TR></TABLE>
I think thats true....but doesn't a b16 work for the b18c5 oil pan??
Maybe the ls pan is different because of lack of vtec...
Old Oct 22, 2003 | 11:47 AM
len's Avatar
len
11200-P30-010 PAN, OIL 1992-93 GSR; 1992-01 LS
11200-P72-010 PAN, OIL 1994-01 GSR; 1997-98, 2000-01 ITR
mitchell_2kSiR
Jul 5, 2009 03:12 PM
Rishiras
Apr 15, 2009 12:54 PM
Hoffy
Apr 22, 2005 04:38 PM
dawalude
Jan 25, 2005 10:49 PM
wtf
Aug 26, 2002 06:23 PM
