Stripping tint off the rear window
Old Oct 19, 2003 | 04:36 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Stripping tint off the rear window
Anyone have any suggestions for taking off the rear tint, besides the amonia trick.
Cause that smells soooooo bad.
I just dont want to strip off the defroster lines.
Old Oct 19, 2003 | 04:43 PM
phatrick2332's Avatar
do u want the tint off, or just the glue? just pull the tint, or use some goo gone or lighter fluid to take the glue off, maybe try some heat applied to the outside of the window?
Old Oct 19, 2003 | 05:17 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (phatrick2332)
go to autozone they have a spray.
Old Oct 20, 2003 | 08:20 PM
johnclaunch's Avatar
Default Re: Stripping tint off the rear window (1 point 6)
Go to a respected local tint shop (one that is dealer recommended) and have them remove it for you.
Old Oct 20, 2003 | 08:23 PM
RiceRacist's Avatar
Default Re: Stripping tint off the rear window (johnclaunch)
its so easy to remove. I just heated it with a blow dry and peeled as much as I could and picked away the edges and make it unsticky with a bottle of goo gone, cost me 3.29 for what Im sure a tint place would charge 50+
Old Oct 20, 2003 | 08:27 PM
Default Re: Stripping tint off the rear window (RiceRacist)
Get it done right by someone qualified is all I'm saying.
Old Oct 21, 2003 | 04:57 AM
bloopie's Avatar
Any good tint shop will charge 5 bucks a window... Id go that route.
Old Dec 3, 2003 | 11:10 AM
tegasaurus's Avatar
Default Re: Stripping tint off the rear window (razorku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razorku &raquo;</TD></TR><TR><TD CLASS="quote">Any good tint shop will charge 5 bucks a window... Id go that route.</TD></TR></TABLE>
edit: 5 bucks per square inch of each window
Heat up the corners of where the tint is with a hair dryer and get a good size peel going. Then as you peel more, keep heating it from the other side of the window.
What's great about living in arizona is you just leave your car outside in august and then just peel away. Simple as can be
Modified by tegasaurus at 12:20 PM 12/3/2003
Old Dec 3, 2003 | 12:07 PM
POE's Avatar
POE
Yo u deff dont want to screw up your defrost, it cost my 35 bucks to have my local window tint place to remove all my old tint, just if u want to be safe.
Old Dec 3, 2003 | 12:54 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (Vtecin94dx)
My local tint place wants 150 to take off the nasty purple tint that is on my car...
Blaze
Old Dec 4, 2003 | 10:00 AM
POE's Avatar
POE
that sucks, Is there any other place that you could trust to do it safely?
Old Dec 4, 2003 | 10:26 AM
dilbert's Avatar
I took my ugly purple tint off my windows before, I just used a knife to get a corner going and then it will all come off at once or in smaller pieces but the glue is the pain in the ***. As someone already said goo be gone works. I asked a tint shop and they said any good quality cleaner will work then just use some glass cleaner to make sure the glue is totally off. They wanted to charge me 20 a window and I was like "nope". and I have been told that at Walmart you can get this metal glue stuff that you can put over a break in the heater lines incase you smoke one and that fixes them.
either way, good luck.
Old Dec 4, 2003 | 10:55 AM
Eresuncabron's Avatar
Default Re: Stripping tint off the rear window (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
[/i]</TD></TR></TABLE>
i agree... i got a qote for 40$ to take off.
Project91CRX's Avatar
well, stripping the film is easy, heat gun/ blow dryer works.
Getting the glue off you can use brake disk cleaner (this is what i used when i was lazy to go buy a bottle of goo gone.. goof off... or whatever they are called)
ramos2589
Paint and Body
Jun 23, 2008 04:12 PM
jimmyxthai
Oct 20, 2006 11:53 PM
9hatch6
May 20, 2006 01:20 PM
syntax.
Feb 7, 2006 03:09 PM
Moemers
Honda S2000
14
Feb 16, 2005 02:54 PM
