Viper Horn Hook Up Integra
Old Oct 19, 2003 | 02:13 PM
ninja8oi's Avatar
Default Viper Horn Hook Up Integra
Can some tell me how to wire up a Viper alarm system to my horn. I have it wired up but the horn is on a continuous honk. Seems like the low current isn't high enough to set the flasher off. I am catching the horn wire at the fuse box relay.
Old Oct 19, 2003 | 07:02 PM
rjr162's Avatar
Default Re: Viper Horn Hook Up Integra (ninja8oi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninja8oi &raquo;</TD></TR><TR><TD CLASS="quote">Can some tell me how to wire up a Viper alarm system to my horn. I have it wired up but the horn is on a continuous honk. Seems like the low current isn't high enough to set the flasher off. I am catching the horn wire at the fuse box relay. </TD></TR></TABLE>
Uhhhh... on honda's if you tag the horn wire on the low current side of the relay, it will be a negitive trigger. You must have tagged on the other side (which typically I'd use a relay so you don't burn up the 200mA output of the brain). Regaurdless, to get it to honk you have to change the setting. Look in the owners manual and/or the install manual... it should tell you how to change the setting from a Constant output to a Pulsed.
jdm_rb20
16
May 2, 2013 09:16 PM
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
ej888
Apr 11, 2011 09:10 PM
MantisX
Aug 27, 2009 03:44 PM
superthug
Oct 27, 2003 05:28 PM
