Camber Kit?
Old Sep 2, 2001 | 12:07 PM
KEVlN's Avatar
New User
Default Camber Kit?
Hey I just recently lowered my car. 2.5 inches. The question is, I dont have my rims yet, but I know I am most likely going to need a camber kit on my car. Right now I am just rolling around on the 14 inch steelies. Ok back to the question, can I go ahead and install my camber kit with the 14's or is it going to change when i put my 16's on? Should I wait untill I get the 16's on. Also, is it a hard installation. I did the springs with not too much trouble. Should I be able to put the camber kit on myself, or is it worth paying for it to be done? All comments appreciated.
Old Sep 2, 2001 | 01:49 PM
fixhondas's Avatar
Default Re: Camber Kit? (Civic95)
The size of your rims has no effect on your camber settings- generally speaking. If you mess with your camber you will need to get an alignment- changing camber will change your toe as well.
Old Sep 2, 2001 | 02:08 PM
KEVlN's Avatar
New User
Default Re: Camber Kit? (fixhondas)
So basically, it is the lowering that messes up the camber? So then I can go ahead and get my camber on...is that correct? And then get an alighnment. And then probably when I get my rims on I will have to get another alighnment? Sorry for my dumbness. Still learning.
Old Sep 2, 2001 | 02:14 PM
fixhondas's Avatar
you can put your kit on and then get an alignment. Your new wheels wont change your alignment- but- larger rims tend to give more accurate alignment readings.
Old Sep 2, 2001 | 04:42 PM
KEVlN's Avatar
New User
thanks
Accord-Guy
Suspension & Brakes
May 12, 2010 03:29 AM
Dirty Octopus
28
Feb 20, 2010 05:47 AM
PearlH22
Sep 10, 2006 04:47 PM
dom93hatch
Apr 19, 2003 10:26 PM
631 Teggy
Jan 18, 2003 07:38 AM
