To people who recently installed Exedy Clutch Kit.......
did you have to adjust the bolt under your clutch pedal??
i've been doing some searching, and it seems like people who have recently installed the clutch didn't have to adjust the clutch.
maybe this was fixed by Exedy.
just wondering.
just wondering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar »</TD></TR><TR><TD CLASS="quote">the racing clutch is not the Exedy Organic OEM style that everyone had trouble with..</TD></TR></TABLE>
Gotcha, wasn't specified so I figured I'd put it out there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgizzles »</TD></TR><TR><TD CLASS="quote">exedy sucks ***.</TD></TR></TABLE>
Why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgizzles »</TD></TR><TR><TD CLASS="quote">get ACT instead.</TD></TR></TABLE>
Why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgizzles »</TD></TR><TR><TD CLASS="quote">even oem is better</TD></TR></TABLE>
In what way?
Why?
Why?
In what way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgizzles »</TD></TR><TR><TD CLASS="quote"> even oem is better </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">
In what way?</TD></TR></TABLE>
Doesn't require clutch master cylinder pushrod adjustment to operate without noise while pedal is depressed, for one. Otherwise, the Exedy is decent, but nothing outstanding really.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">I just put in the excedy racing clutch, chromoly LWFW all at the same time. For me I don't have to adjust it. Worked out fine for me.</TD></TR></TABLE>
x2'ish
x2'ish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zzzvtakzzz »</TD></TR><TR><TD CLASS="quote">cable tranny i think you have to. but hydro tranny dont have to you think.</TD></TR></TABLE>
ITR = hydro tranny..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asse »</TD></TR><TR><TD CLASS="quote">Do you recommend the Exedy organic clutch kit stage 1 for track use?
I noticed that the oem clutch cant handle the heat so well...</TD></TR></TABLE>
not sure what the stage 1 gets you..? I assume that's the one with the OEM style disc and the heavier duty pressure plate.. otherwise, the exedy organic is basically the same as the OEM..
not sure what track use you mean(HPDE, RR/AX, drag, dorifto,etc), but just skip all the hassle and buy an ACT or something..
i hear people saying this shii and there are people saying they had no problem whatsoever . with exedy clutch.
there's always 2 different side of stories.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">
there's always 2 different side of stories. </TD></TR></TABLE>
there are also 2 different types of clutches that they make..
