Help My car wont start!!!!
Old Oct 19, 2003 | 08:17 AM
atli126's Avatar
Default Help My car wont start!!!!
ok guys my distributor went out and i got a used one, and we put it on , and now my car is firing and igniting like it should,
i know that my distributor is good compared to my old one.
i have pulled the spark plug wire out put it on top of the motor , and you can see it spark, i thought it could have been my fuel pump but i took out my filter and cranked it and fuel shot out , so my pump is pumping , but now i dont what to do i would love to have someone lend a helping hand if they have any ideas.
thanks
Bret
Old Oct 19, 2003 | 08:24 AM
FULL-RACE EP3's Avatar
Default Re: Help My car wont start!!!! (atli126)
I know this may sound pretty vague and almost a bit silly, but if it was working fine before your distributor went bad and now with the new distributor it doesnt, I'd say your problem lies right there. Again this may be stating the obvious but I'd start looking into this "new" distributor and work from there.
Old Oct 19, 2003 | 08:51 AM
cmalibuu's Avatar
ok dude, tale open up the distributer up, and make sure the rotor has the screw in it holding it to the distributer shaft, under the distributer cap, because the plugs will still spark, but the rotor could be ferrly spinning, check that and get back with me!!!!!!
Old Oct 19, 2003 | 09:52 AM
civickiller's Avatar
Default Re: (cmalibuu)
r u getting any codes
Old Oct 19, 2003 | 10:00 AM
senpai's Avatar
Since this happened after your distributor install, I think you may have the firing order mixed up.
Old Oct 19, 2003 | 10:23 AM
hontegra's Avatar
what year is the car
check the wires,firing order and check to see if the shaft is on right
Old Oct 19, 2003 | 11:04 PM
crxY-49's Avatar
check to see if your plugs are wet with fuel...if not you have fueling issues
Old Oct 19, 2003 | 11:16 PM
Caleb V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmalibuu &raquo;</TD></TR><TR><TD CLASS="quote">ok dude, tale open up the distributer up, and make sure the rotor has the screw in it holding it to the distributer shaft, under the distributer cap, because the plugs will still spark, but the rotor could be ferrly spinning, check that and get back with me!!!!!!</TD></TR></TABLE>
Ditto that, I got stumped on a customers car with that nasty distributor trick.
If you ever get an afteramarket new OEM style distributor they have a nasty tendency to install the wrong sensors to the wrong color of wire. Try and test both distributors on a known running car unless you have some time, a helm manual and a multimeter.
ratchetEDsedan
14
May 30, 2017 07:08 PM
galognu
Nov 6, 2016 08:57 PM
brokenojoke
Mar 20, 2006 02:43 PM
GQ Cowboy
Dec 14, 2003 09:55 PM
