who sells brembo solid front discs
Old Oct 19, 2003 | 08:01 AM
crxaddikt's Avatar
Default who sells brembo solid front discs
nopi only carries the vented fronts, but they have the solid rotors for the rear, and they are cheaper, so i was wondering if anyone knows who carries the fronts for crx 90 si (solid rotors) , not vented or slotted cause they are too much $$, any info would be cool, thnx
Old Oct 19, 2003 | 08:03 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: who sells brembo solid front discs (crxaddikt)
NOBODY.
Somebody correct me if I am wrong, but as far as I know nobody makes SOLID front rotors. They are all vented.
The difference is slotted or drilled or both.
Old Oct 19, 2003 | 10:34 AM
carsaregood's Avatar
yeah, do you mean slotted/drilled vs regular vented? if so, you can get them at tirerack.
http://www.tirerack.com/brakes...Rotor
Old Oct 19, 2003 | 10:50 AM
Vinceg99's Avatar
Default Re: who sells brembo solid front discs (carsaregood)
Another place you can find them is Ebay. The Brembo blanks arent on there as much as say the drilled or slotted but you will find them on there from time to time.
Old Oct 20, 2003 | 01:03 PM
crxaddikt's Avatar
Default Re: who sells brembo solid front discs (Vinceg99)
i guess that explains why a while back when i ordered the front blanks, they shipped me rear ones? but i ended up keeping and installing them, but now my fronts are warped, and i need to put new ones again, and maybe i will just get the vented ones, i can afford them, but i just heard they crack between the holes or something on a post a while ago, so i was skeptical, but i always thought they looked cooler, but it does'nt matter how they look, since you can't see them that good through 90 teardrop si wheels anyway.
i'll check ebay, thanks
Old Oct 20, 2003 | 01:05 PM
njn63's Avatar
i think you are mistaking vented for cross drilled or slotted. Doesn't vented mean the venting between the surfaces? I know the ones on the front of my car currently are that way and the rear ones aren't.
Old Oct 20, 2003 | 01:09 PM
^jefs0ng's Avatar
Banned
The blanks are cooler if you ask me.. There was that white dc-5 in the appearance or something with a groove around the rotor in a circle.. looked cool..
Old Oct 20, 2003 | 03:34 PM
EL Vap133's Avatar
http://www.nopi.com
Old Oct 20, 2003 | 04:42 PM
my_slow_civic's Avatar
Default Re: who sells brembo solid front discs (EVIL_Vap133)
http://www.groupbuycenter.com
bby6
Apr 11, 2005 06:35 AM
xclusionx
Nov 5, 2004 08:06 PM
aZnjCC
Aug 25, 2004 08:47 AM
jason_alt
Apr 22, 2003 10:42 AM
Wai
Jan 20, 2002 06:24 PM
