alternator install
ok, my alternator is bad and i need to install a new one. it looks to me that i have to take my engien out to install it. could i mayve take apart my alternator, slip it down there, and reassemble it? i dont wanan take out my engine again b.c its a bitch and i just took it out 2x in one day. and then my alternator stops wokrign... but yeah any solutions for me?
i checked it all out and **** that seemed liek the only way. ill go check it out again i didnt really think of dropping it out the bottom... *(hammer on head symbol i dont know how to do)* maybe ill try that..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 »</TD></TR><TR><TD CLASS="quote">Drop it out the bottom....</TD></TR></TABLE>
Its usually not that easy.
However you DO NOT have to take out the motor
. Just pop out the driver side axle and ta dah!!
dude, some of these guys will proly disagree w/ me, but the easiest way for me is out the top. Take off the (2) 10mm nuts holding the master cylinder to the brake booster. Carfuly have someone pull it out of the wayy while you pull the alt. out
Just dont get crazy and bend the lines at a 90 degree angle or something
I did mine 3 times already this week (damn Autozone rebuilt alternators
It should take you 15 min to get it out and the other back in.
edit:DIDNT REALIZE IT WAS A 1st GEN. MY BAD:
. It should take you 15 min to get it out and the other back in.
i put mine in through the front, like where the engine pulley is, but i had to take off the pulley and take off the lower bracket on the alternator mounts, i had a hard time getting it in there but after alittle wiggling i got it
That's how I changed mine out a couple of weeks ago. I just took the master cylinder off (very carefully, to be sure not to damage it and have to get a new one), and the alternator just came right out. I popped the new alt. in, put the old MC back on, bled the brakes, and everything was good again.
