Should I use an OEM throw-out bearing with my Exedy clutch?......
Old Oct 18, 2003 | 06:53 PM
TypeRuz's Avatar
Default Should I use an OEM throw-out bearing with my Exedy clutch?......
or should i use the bearing that came with it??
i heard the bearing has alot to do with the problems with the Exedy kit.
Old Oct 18, 2003 | 07:58 PM
BlueR's Avatar
Default Re: Should I use an OEM throw-out bearing with my Exedy clutch?...... (typeruz)
do you have an OEM bearing handy? or do you have to purchase one?
if you have both, use the OEM one
Old Oct 18, 2003 | 08:21 PM
Dan GSR's Avatar
Default Re: Should I use an OEM throw-out bearing with my Exedy clutch?...... (BlueR)
my exedy kit came with an OEM bearing
Old Oct 19, 2003 | 08:30 AM
Bbasso's Avatar
I use OEM tb bearing with my ACT...
Old Oct 19, 2003 | 08:33 AM
ultimatehonda's Avatar
My action 1ms clutch came with a oem bearing. It said the same name on it so i think it is. What does the exedy say on it?
Old Oct 19, 2003 | 08:45 AM
TypeRuz's Avatar
Default Re: Should I use an OEM throw-out bearing with my Exedy clutch?...... (Dan GSR)
my throw-out bearing says "NACHI Made in Japan"
is that the OEM bearing??
oh, and my pilot bearing says "NTN Made in Taiwan"
is it OEM?
thanks!
Old Oct 19, 2003 | 10:08 AM
Thats what the oem bearing says too.
Old Oct 19, 2003 | 10:31 AM
TypeRuz's Avatar
Default Re: Should I use an OEM throw-out bearing with my Exedy clutch?...... (ultimatehonda)
great, i have the OEM bearing!
thanks!
1sikhatch
May 23, 2009 04:45 PM
3.point.2
May 26, 2006 01:35 PM
Lifter2012
Jan 24, 2006 03:13 PM
TypeRuz
Oct 18, 2003 07:45 AM
