**What did you do to prep your WW kit?**
Old Oct 18, 2003 | 03:16 PM
GreenMachineRex's Avatar
Default **What did you do to prep your WW kit?**
as above...thanks
Old Oct 18, 2003 | 10:36 PM
4inspeed's Avatar
Default Re: **What did you do to prep your WW kit?** (GreenMachineRex)
you can send it to me for prep and fitment
just playin, use that plastic/urethane stripper, then sand it down and you should be all good. well plus paint.
Old Oct 19, 2003 | 08:15 AM
where can i get that stuff? and bump...
i was told to leave it outside in the sun and rain, then scrub it down with soft scrub/ or ajax..
then sand away...
Old Oct 19, 2003 | 10:43 AM
brent_G's Avatar
Default Re: (GreenMachineRex)
ur gonna need elastic primer or something like that to make the paint stick and not crack. Dunno where exactly what its called but you cant use normal primer. I just remember when my buddy has hit kit sprayed and after a year the paint was flaking off and lil cracks all through it from stress and heat and cold...whatever it may have been
Modified by screamincivik at 9:52 PM 10/19/2003
Old Oct 19, 2003 | 12:56 PM
you use adheasion promotor to make it stick...
Old Oct 20, 2003 | 11:01 AM
BoostedEF's Avatar
How did you get your door caps to stick properly ? I find it impossible to get a screw somewhere on the top . I put on ny rex and the top part of the door cap kept unsticking. N-E-1 know where to get that flex primer or paint ??? Also did your kit line up perfectly to the stock body lines ? Door caps alittle short ?
bluenc-87
Paint and Body
Jun 19, 2009 07:14 PM
bigsnorlax
Paint and Body
Mar 16, 2009 04:47 PM
silverskateEF9
Paint and Body
Oct 30, 2007 03:50 AM
CALM_AS_A_BOMB
Dec 5, 2005 11:05 PM
ImportHatch
Apr 30, 2002 11:39 PM
