Got my new motor in, but need some HELP!!
Old Oct 18, 2003 | 01:59 PM
4gzchatch's Avatar
Default Got my new motor in, but need some HELP!!
I just got my z6 in my new crx, but I can't get it to start. worse, it won't even turn over. It just clicks. I have checked my grounds, and I am getting power to the starter solenoid, and i am pretty sure it is getting to the motor too... Any ideas? I have had to do a lot of rewiring on this car, but it should still turn over as long as those two things are in place, right? Any help would be great!!!
Old Oct 18, 2003 | 04:17 PM
4gzchatch's Avatar
Default Re: Got my new motor in, but need some HELP!! (4gzchatch)
Bump....
I'm also getting 4 codes:
6 (coolant temp)
10 (intake air temp)
13 (atmospheric press.)
20 (electric load)
Where do I even start with this?
Electronics suck! (yeah, yeah, I know, it wouldn't work without them...)
Old Oct 18, 2003 | 06:53 PM
sporkcrx's Avatar
Is the starter known to be good? When mine went out it would do the same thing.
Old Oct 18, 2003 | 09:26 PM
91civicEX's Avatar
Default Re: Got my new motor in, but need some HELP!! (sporkcrx)
is the battery good? can you turn your motor over by hand?
Old Oct 19, 2003 | 10:14 AM
cstay's Avatar
Default Re: Got my new motor in, but need some HELP!! (91civicLX)
are u sure u have a full amount of power from the battery. if u read the power at the starter without a load it will read 12 volts but once u put a load on it if its a bad battery it will drop.
Old Oct 20, 2003 | 06:42 PM
4gzchatch's Avatar
the battery is fully charged, i can turn the motor by hand, and the starter worked fine when the old motor was last run. I haven't tested the power at the starter. you mean that I should put a tester on the solenoid connector, test it with the car off, and then test it when I turn the key? How much power should I get if the battery is good?
The code that I'm getting that's the problem is the 20. What could be putting too much load on the car? There is an alarm on it, but as soon as the key turns, it should be deactivated, right?
thanks for your help!
Old Oct 20, 2003 | 07:34 PM
sporkcrx's Avatar
Default Re: (4gzchatch)
Can you push start it? If so the starter may of taken a crap.
Old Oct 20, 2003 | 08:24 PM
I8ayellowcrayon's Avatar
I had that problem, it was my starter relay. So I just bypassed it and put in a push button switch. Try shorting out your starter (best if taken out first) .
Old Oct 20, 2003 | 09:37 PM
potator's Avatar
Search is your best friend.
Old Nov 3, 2003 | 07:24 PM
4gzchatch's Avatar
I got some input from some friendly guys here saying that I needed to change some wiring, and that I needed to fix my tdc sensor wiring. I have done this, but am still not getting any response from the starter. Can someone please give me more detailed information on how to test the starter and the power at the starter? I appreciate it a ton!!!!
Old Nov 5, 2003 | 02:27 PM
to test your starter, disconnect the relay clip on top of the stater. You'll need some wire to go from the positive post on the battery to that clip. Just touch the wire to the clip and see if it does anything; don't hold the wire on the starter for a long time. You can also take the starter to Auto Zone, and they should test it for free.
Old Nov 5, 2003 | 02:32 PM
brent_G's Avatar
Default Re: (potator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by potator &raquo;</TD></TR><TR><TD CLASS="quote">Search is your best friend.</TD></TR></TABLE>
? yeah people cover this one all the time
soundsl ike you heard that one before and felt like using it on someone else
Old Nov 5, 2003 | 06:51 PM
4gzchatch's Avatar
I did the test you mentioned, but still just get a click, so I pulled it and I'm going to get it tested tomorrow. Hopefully (crossing all my fingers and toes) it will start once I can get this crap straightened out! Otherwise, there will be new posts from me!
Old Nov 5, 2003 | 07:10 PM
Yeah, I'd say its bad, but while you're at Auto Zone getting a new one, get it tested, cheap insurance. Or free for that matter.
Old Nov 6, 2003 | 08:02 AM
4gzchatch's Avatar
The funny thing is that it worked fine before the old motor was pulled. However, it did sit around for a while, can a starter just go bad spontaneously? Seem weird to me, but whatever. Hopefully, this is a deep as the problems get! (but I know better than to hope!)
Old Nov 6, 2003 | 10:00 AM
Now that I think about it, my starter went bad like that too. I pulled the engine, put everything back in, and it just wouldn't work. I thought that was strange also. I don't know why it would do that, but oh well.
Old Nov 6, 2003 | 08:21 PM
4gzchatch's Avatar
Well, the starter's bad... I'm gonna hit the boneyard tomorrow and pick one up, We'll see how far that gets me!!
kevinoneill
39
Jul 6, 2010 03:22 AM
dukevt
Honda Civic (2001 - 2005)
Feb 11, 2009 12:08 PM
boosted timebomb
May 9, 2007 11:11 PM
91ed9
Dec 24, 2006 04:21 PM
JSpecwest
Dec 26, 2001 09:47 AM
