What brand FRONT camber kit do you recommend?
Old Oct 18, 2003 | 11:38 AM
E-lude78's Avatar
Default What brand FRONT camber kit do you recommend?
I can't decide between Specialty or Ingall's. If there are any other brand's you recommend, lemme know.
Old Oct 18, 2003 | 11:54 AM
QTKEG6's Avatar
Default Re: What brand FRONT camber kit do you recommend? (Mista B-one-seven)
speciality was weak before, but they recently made 3 degree kits, but ingalls has been around for a while. speciality is cheaper, ingalls is more. theres also progress and revel.i'd pick ingalls though. used them before.
Old Oct 18, 2003 | 11:57 AM
phan's Avatar
Default Re: What brand FRONT camber kit do you recommend? (QTKEG6)
i'm using ingalls up front...
i had to grind out some metal from inside the fenderwell because the camber kit would rub and keep the front from dropping completely. i took a grinder to it and solved the problem...
aside from that, the ingalls kit seems to work well...
Old Oct 18, 2003 | 12:05 PM
d357r0y's Avatar
Progress
non adjustable.. but who actually gets down under their car and adjusts their camber?
Old Oct 18, 2003 | 12:11 PM
phan's Avatar
Default Re: What brand FRONT camber kit do you recommend? (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">Progress
non adjustable.. but who actually gets down under their car and adjusts their camber?</TD></TR></TABLE>
::raises hand::
i was tired of wasting the inner part of expensive tires...
Old Oct 18, 2003 | 12:37 PM
d357r0y's Avatar
Default Re: What brand FRONT camber kit do you recommend? (phan)
then adjust your toe, not your camber.
Old Oct 18, 2003 | 01:11 PM
spaceman's Avatar
A-sports make the best but its alot more money
Old Oct 18, 2003 | 05:17 PM
E-lude78's Avatar
jdmhondaparts sells vision front camber kits but those are way too much $$$
Old Oct 18, 2003 | 10:34 PM
4inspeed's Avatar
hmm, i like spc, i got he ones that are up to 3, cause my camber was bad.
Old Oct 18, 2003 | 11:25 PM
buckNasty's Avatar
what about eibach?
Old Oct 20, 2003 | 02:03 PM
E-lude78's Avatar
Default Re: (bucbaby)
I'm going with Ingall's. Thanks for your help.
Old Oct 20, 2003 | 07:21 PM
neutron91's Avatar
progress sucks *** if you have springs... if you have coilovers its better cause you can get the camber closer to 0... but then your car may not be as low as you want... that sucks also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote"> but who actually gets down under their car and adjusts their camber?</TD></TR></TABLE>
i do... i have ingalls up front... its by far the best imo... i also had to beat out some of the unibody in order for the balljoint to clear and settle properly as someone else said... i opted to pound it with a hammer instead of cutting/grinding it out
bikerbo1
Apr 16, 2008 11:42 AM
taimysho0
Feb 6, 2008 08:14 AM
guero2craze
Suspension & Brakes
Feb 22, 2007 09:53 AM
bryandamatrix
Jul 18, 2004 01:00 AM
i3luemrld
Feb 6, 2004 11:44 AM
