MINI_ME pain in the @$$
Old Oct 18, 2003 | 07:10 AM
** OF HAZARD's Avatar
Default MINI_ME pain in the @$$
I had to chase each head bolt hole! I am just so pissed everything that could go wrong went wrong!
Old Oct 18, 2003 | 07:58 AM
Grease Monkey's Avatar
Default Re: MINI_ME pain in the @$$ (****S OF HAZARD)
Old Oct 18, 2003 | 08:44 AM
turboZChatch's Avatar
Default Re: MINI_ME pain in the @$$ (Grease Monkey)
What do you mean you had to chase them like helicoil them?
Old Oct 18, 2003 | 10:43 AM
Default Re: MINI_ME pain in the @$$ (turboZChatch)
Have you ever heard of a tap and die set? I am sure you have! i had to "re-thread" the holes!!
Old Oct 18, 2003 | 10:46 AM
let me tell you. After all the times i've worked on cars, nothing ever goes perfect. Something you should understand before you do anything. Always prepare for the worse.
Old Oct 18, 2003 | 10:52 AM
filthyCREX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote"> Always prepare for the worse.</TD></TR></TABLE> SERIOUSLY!
Old Oct 18, 2003 | 11:24 AM
Default Re: MINI_ME pain in the @$$ (filthyCREX)
yeah everything is going wrong i will tell more when i get time!!
Old Oct 18, 2003 | 02:21 PM
Starbucks_91b16acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">let me tell you. After all the times i've worked on cars, nothing ever goes perfect. Something you should understand before you do anything. Always prepare for the worse.</TD></TR></TABLE>
hell yea.. what swap ever goes without anything bad happening, something always ***** up
Old Oct 18, 2003 | 02:31 PM
JAMinCiViC's Avatar
Default Re: MINI_ME pain in the @$$ (91b16aCRX)
True that!! Why does it always come down to the last bolt or the last step!!! had to vent also
Old Oct 18, 2003 | 02:40 PM
PhatOptimo's Avatar
Default Re: MINI_ME pain in the @$$ (JAMinCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAMinCiViC &raquo;</TD></TR><TR><TD CLASS="quote">True that!! Why does it always come down to the last bolt or the last step!!! had to vent also </TD></TR></TABLE>
Just to **** you off more.
Seriously though, taking your time and knowing what the hell you are doing helps (most of the time).
Old Oct 18, 2003 | 02:49 PM
CB_ejcoupe's Avatar
I just did this swap yesturday on my car, and i also had to rethread, only one hole tha rest came out good.
Old Oct 18, 2003 | 02:58 PM
Default Re: MINI_ME pain in the @$$ (CBtech)
i had to re-tap everyone!! The head gasket seemed like it was welded on along with the intake gasket!! I got the wrong head bolts the list goes on and on!! I got the car with no motor no interior or exterior harnesses!! So i had to swap harnesses from my dx CRX to the new civic SI and now i have to convert it to multi-point its a pain in the ***!! Still have lots to do!!! it just feels good to vent thanks for listning!!!
fcukt_teg
Nov 30, 2007 04:03 PM
rainydayman
16
Oct 24, 2005 08:23 PM
2ltrEK
Aug 25, 2004 07:02 AM
jh4db8teg
Jun 1, 2004 03:00 PM
