whirring with clutch in.
Old Oct 17, 2003 | 03:48 PM
corona's Avatar
Default whirring with clutch in.
i own a 1990 honda accord dx.
i've noticed a pretty loud whirring sound, when the car is in gear with the clutch in. it only happens when you put the clutch in after it's been in the gear...and there's no sound when it's in nuetral
it was in a minor head on collision [when it was parked]...and i've noticed the sound has increased since then.
any ideas? i'm sure this has been discussed before, but i searched & didn't come up with anything.
i'm actually trying to sell it right now, but i'm interested in what the sound could be
thanks, i appreciate it.
tifish.
Old Oct 17, 2003 | 04:07 PM
WuWarrior's Avatar
Default Re: whirring with clutch in. (corona)
I think this is normal while the car is in neutral. As long as it doesn't make noise while it's in gearl
Old Oct 17, 2003 | 04:17 PM
corona's Avatar
Default Re: whirring with clutch in. (WuWarrior)
the car is in gear with the clutch in when it makes the noise.
Old Oct 17, 2003 | 06:35 PM
Eddiebx's Avatar
if its only making noise when you have the clutch pressed in, it could possibly be the throw out bearing going out on you.
Old Oct 17, 2003 | 07:03 PM
corona's Avatar
Default Re: (Eddiebx)
k...i'm not much of a car guy...about how much $ would that run me?
thanks,
tifish.
Old Oct 18, 2003 | 08:29 PM
-RedneckDave-'s Avatar
Working
Default Re: (corona)
I agree, that sounds like a throw out bearing and to replace it is pretty much like replacing a cluthch except you are only replacing the trouw out bearing and not the clutch but you might as well replace the clutch while you have everything apart if you can afford it.
Inextricabledrvr
Oct 22, 2013 10:18 PM
DeeJaaY209
14
Sep 15, 2013 10:40 PM
Accordguy09
Transmission & Drivetrain
Aug 15, 2013 01:46 PM
RefuseRice
Oct 19, 2004 10:16 PM
echo999
Feb 4, 2002 04:41 PM
