Bad Fuel Rail? OR incorrect DPFI to MPFI wiring? Leaking fuel
Old Oct 17, 2003 | 11:21 AM
SOHCEK-Turbo's Avatar
Default Bad Fuel Rail? OR incorrect DPFI to MPFI wiring? Leaking fuel
After I started the car I noticed fuel leaking from ethier a possible busted fuel rail or did I miss something on the fuel injectors wiring. I am going full obd1 that is the injectors, dizzy and ecu p28. From what Blownhatch told me is that I dont need a resistor box for these injectors so what I did is connect the the 2 yellow/black wires from the dpfi to the 8 yellow/black wires (junction c128) connection I cut off the obd1 harness to extend other 4 yellow/black wires on to the injectors. So what I want to know is if this wiring correct? or did I screw up or do I need to ground a yellow/black wire from the junction 128 connector? Or maybe I need a new fuel rail. Any help is great.
Old Oct 17, 2003 | 02:03 PM
matt j's Avatar
Default Re: Bad Fuel Rail? OR incorrect DPFI to MPFI wiring? Leaking fuel (civicdriver91)
check the injector seals first, i dont see why you would be leaking fuel through wiring.
Old Oct 17, 2003 | 10:35 PM
Default Re: Bad Fuel Rail? OR incorrect DPFI to MPFI wiring? Leaking fuel (matt j)
Thanks Ill check my injector seals.
Does anyone else have anymore sugestions?
Old Oct 17, 2003 | 10:37 PM
xvracing's Avatar
make sure all of your fuel lines are on tight. I didnt tighten the FPR line and it leaked all over the place. Fuel rails don't usually break. Most likely its the seals.
Old Oct 18, 2003 | 10:01 AM
ThatRicerDaniel's Avatar
make sure you have all the washers that go around the fuel lines. where is leaking from eaxtly ? from the injector or from the line ? or like where the injector meets rail or where the injector meets the head or where the fuel line meets the rail.
Old Oct 18, 2003 | 11:45 AM
Default Re: Bad Fuel Rail? OR incorrect DPFI to MPFI wiring? Leaking fuel (NitrousDreamz)
Its leaking from the injectors Ill check the seals today.
Thanks guys
How about my mpfi wiring I know the (red, brown, lt blue,yellow wires) on the injectors are ok. But how about the 4 yellow/black wires. I basically have them wired all together with the other 2 existing yellow/black wires that came from the dpfi red, yellow injectors. Is this cool or is it wrong?
Since they are d16z6 injectors and they dont need a resistor box I really dont know how to wire the yellow/black wires I am guessing my wiring is correct unless someone else proves me wrong.
Old Oct 18, 2003 | 12:25 PM
phan's Avatar
yea, check the o-rings around the injectors. a chewed up / bad o-ring will cause a lot of leakage...
Old Oct 18, 2003 | 12:49 PM
Default Re: Bad Fuel Rail? OR incorrect DPFI to MPFI wiring? Leaking fuel (phan)
It is the O ring. That is exactly were it is leaking from.
Thanx
Old Oct 18, 2003 | 01:09 PM
phan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdriver91 &raquo;</TD></TR><TR><TD CLASS="quote">It is the O ring. That is exactly were it is leaking from.
Thanx</TD></TR></TABLE>
a lot cheaper than buying injectors or a rail...
...like some of us idiots do.
Old Oct 18, 2003 | 01:19 PM
Cool thanx.
How about my mpfi wiring, I am still questioning it I did this since someone was aking about this on another thread when I did a search but there was really no final answear.
elmalouno
38
Apr 18, 2019 03:18 PM
meloylo
Nov 14, 2007 02:08 PM
jumpmann23
Aug 5, 2003 05:37 PM
