Installing Turbo
Old Oct 17, 2003 | 09:01 AM
gizdawg's Avatar
Default Installing Turbo
Does anyone know where I can find installation procedures on bolting on turbos to my accord 2001 i4?
iam7head's Avatar
Default Re: Installing Turbo (gizdawg)
is that a kit?
Old Oct 17, 2003 | 09:06 AM
gizdawg's Avatar
Default Re: Installing Turbo (iam7head)
No! I bought parts seperately. Do you think I can bolt on 2-3 turbine on my car... is that possible??
Old Oct 17, 2003 | 09:31 AM
iam7head's Avatar
why you need so many? lol one for each cylinder??
if you want more power
worry about tuning, internal back pressure and boost creep instead
need help with turbo? I am in pasadena..
hey that would really help if you post all the picture
Old Oct 17, 2003 | 09:44 AM
gizdawg's Avatar
Well, I only have one turbine, piping from the engine to the turbine, no waste gate yet, no intercooler yet, and one piping to the exhaust ...and I need to get a hold of the header too... any ideas ...
Old Oct 17, 2003 | 10:14 AM
Nick H's Avatar
New User
wtf? dude, you bolt the turbo manifold on where your stock exhaust manifold goes...then you bolt on the turbo, and connect the downpipe to your turbo, and put on the wastegate as well...afterwards, you mount the intercooler where you want it, and then have the piping custom welded it if isn't already pre-bent...make sure that you have a shop put a bung in the pipe going from the intercooler to the intake manifold so that you can put your blow off valve in...then you need to tap your oil pan so that you can connect an oil return line...you also need to figure out a way to get an oil feed line to the turbo as well...put in your new injectors and then wire in your a/f computer and you should be good to go...lemme know if i forgot anything...
Old Oct 17, 2003 | 12:31 PM
soccerstudj's Avatar
Default Re: Installing Turbo (Nick H)
might be a good idea to get better fuel management... tune it, and just hope nothing blows...
Old Oct 17, 2003 | 01:27 PM
iam7head's Avatar
Default Re: Installing Turbo (soccerstudj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccerstudj &raquo;</TD></TR><TR><TD CLASS="quote">might be a good idea to get better fuel management... tune it, and just hope nothing blows...</TD></TR></TABLE>
it's not only good, it's nessary!!
Old Oct 17, 2003 | 02:07 PM
gizdawg's Avatar
Thanks yall... everything sounds good...only good though when I'm actually working on it... I had a friend who has a H22A on his accord with a bolt on 2 turbine connecting one after another with 2 cold air intake. It ran smooth and cranked 545 bhp on the dyno, until something happened... there was a leakage in the oil line and one of the compressor on the one of the turbo blew out and his car jerked really fast... I thought it was on crack... what do you guys think happened?? What would be his mistakes.... any ideas???
Old Oct 17, 2003 | 02:36 PM
97F22B2's Avatar
are you on crack or am i reading your posts wrong? he had two TURBOS on an H22?
Old Oct 17, 2003 | 03:03 PM
1994AccordSiR's Avatar
Default Re: (97F22B2)
thats wut i was planning on doin a good ways down the road
Old Oct 17, 2003 | 03:28 PM
gizdawg's Avatar
Default Re: (1994AccordSiR)
... you have to see it to believe it... but yes.. two turbine..one connect via an ceramic coated pipe. It sounds naturally aspirated ... but its all volumetric power... whether you believe it or not. .... anything is possible ....
97F22B2's Avatar
two turbos on a honda are just not worht it(unless your a V6 owner). why do you think most twin turbo guys go with a single BIG setup. dual rotor RX-7's go single or a tri rotor with upgraded secondary. Stay with a single and get a big *** slug, two is too much of a hassle, unless you want it for show or some kind of proof that it can be done.
Old Oct 17, 2003 | 03:29 PM
gizdawg's Avatar
Default Re: (gizdawg)
... the only problem I have on mines... I haven't fully understand how the turbo works... I have only experienced it..but not have fully understood it... all of it..
Old Oct 17, 2003 | 03:59 PM
97F22B2's Avatar
Read Maximum boost by Corky Bell. Then do boost.
Old Oct 18, 2003 | 04:52 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97F22B2 &raquo;</TD></TR><TR><TD CLASS="quote">Read Maximum boost by Corky Bell. Then do boost.</TD></TR></TABLE>
excellent book btw, i read it
if you are not sure what the hell is going on, you are not really for turbo.
learn before wasting anymore money, save it for a turbo seal rebuilt later down the road
anyways, got any picture mang? how your buddy connect two turbine with one compressor? I am sure they would not spin at the same rpm, ever with equal length manifold and such and such
I am really skeptical, throw me some picture.
Old Oct 18, 2003 | 05:25 PM
97F22B2's Avatar
dito
1badteg
Oct 21, 2007 01:45 PM
boostdcivic
May 24, 2007 10:23 PM
zexifiedlude
Nov 30, 2005 09:00 AM
Talon12bp
Nov 27, 2003 07:52 PM
