MAP code 3 obd 0-1 conversion issue...
I'm having massive issures with my map sensor. there are 3 wires... yellow red/green and white brown.
+5v -5v and data....
anyway... ive hooked it according to the pinouts but i cant get the map code to clear.. code 3
It is a 89 crx with a A6 block and a y8 head.
I spliced the harness and this is the only code remaining.... since ive converted to odb1.
I ran 3 NEW wires to the map and now am confused about the pinnouts because the write ups say the hasport manual is wrong.. which do i use?
Pinns 21,19 ,17 on d connector of the obd 1 ecu are the map pinns im using...
-x m d
-x m d
regal1975
Jun 6, 2014 08:46 AM
speedooo
11
Jul 24, 2008 09:27 AM
philosofy1
10
Aug 26, 2006 07:35 AM
