My SIR II Dyno in an EF!!!
Old Oct 16, 2003 | 09:18 PM
bossman032's Avatar
Default My SIR II Dyno in an EF!!!
first gear PULL.
I have stock motor with some no brand short ram intake and 2 1/4 inch piping from muffler tech and some cheap muffler.
second gen b16a OBD1 from Xsi with YS1 tranny and PR3 ECU.
Old Oct 16, 2003 | 09:23 PM
SimbaDogg's Avatar
Default Re: My SIR II Dyno in an EF!!! (bossman032)
hey man...those are some pretty weak numbers. is this the jdm sir II motor, the 170 hp variant? did you do compression/leakdown tests?
Old Oct 16, 2003 | 09:26 PM
bossman032's Avatar
Default Re: My SIR II Dyno in an EF!!! (SimbaDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">hey man...those are some pretty weak numbers. is this the jdm sir II motor, the 170 hp variant? did you do compression/leakdown tests?</TD></TR></TABLE>
lol weak I think you need to think again!!!
thats not weak numbers tust me people that dyno b16a all day said its healthy strong *** motor
Old Oct 16, 2003 | 09:27 PM
bossman032's Avatar
your regular b16a cant do 150HP 100% positive maybe on mustang dyno .
Old Oct 16, 2003 | 09:37 PM
SimbaDogg's Avatar
trust me, i've seen usdm b16's (160 hp) and jdm 1st gens the same amount of power at the wheels. even with a crappy intake and muffler, i'd expect more than that.
Old Oct 16, 2003 | 09:41 PM
bossman032's Avatar
Default Re: (SimbaDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">trust me, i've seen usdm b16's (160 hp) and jdm 1st gens the same amount of power at the wheels. even with a crappy intake and muffler, i'd expect more than that. </TD></TR></TABLE>
LOL. sorry but I don't believe that proof it with a dyno graph.
If you have a regular b16a OBD0 and doing 160HP you must have some after market stuff like valve springs etc..even with CTR cams u dont do that much on the regular B16a.
Old Oct 16, 2003 | 09:49 PM
SimbaDogg's Avatar
Default Re: (bossman032)
thats me w/ an aem shorty...is that proof enough? the same day, about 4 different obd 2 b16s (2 99-00 si coupes close to stock) were making 140-145 hp, a struggling itr made 158, and an h22 made 165
now why would i lie? look @ my sig
Old Oct 16, 2003 | 09:54 PM
bossman032's Avatar
I don't see nothing.
to proof a point my friend has B18c GSR pulled 155whp and 115Tq with his b18c crx.
hmm those motors were struggling on the dyno some good motors!!!
Old Oct 16, 2003 | 09:59 PM
SimbaDogg's Avatar
jdm b18 or usdm b18c (170 or 180 hp)?
Old Oct 16, 2003 | 10:18 PM
Mr Hammond's Avatar
a/k/a Jomo
That's a normal B16A. Wake up man.
Why the 1st gear pull?
Old Oct 16, 2003 | 10:28 PM
smnowell's Avatar
Default Re: My SIR II Dyno in an EF!!! (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">That's a normal B16A. Wake up man.
Why the 1st gear pull? </TD></TR></TABLE>
yeah, I was wondering the same thing. Aren't dyno runs usually done in either 3rd or 4th gear? Wouldn't 1st gear give you slightly innaccurate numbers? Then again, I could just be talking out of my ***....it is 2:30am...
Old Oct 16, 2003 | 10:55 PM
chris@allmotor.net's Avatar
Default Re: My SIR II Dyno in an EF!!! (b16a ferio)
ya, iw as about to ask about the first gear pull...why? isnt third best for b16s?
Old Oct 17, 2003 | 12:32 AM
MikeySpec's Avatar
Good job.Im glad you're happy....with those average numbers!Keep up the good work!
Old Oct 17, 2003 | 09:59 AM
eRACING's Avatar
Default Re: My SIR II Dyno in an EF!!! (MikeySpec)
Why waste a dyno pull in 1st gear..the results won't even be close to accurate... Dyno in 4th gear in any b-series cause its more of a 1:1 ratio.
Old Oct 17, 2003 | 10:11 AM
TwoRedEGgs's Avatar
Default Re: My SIR II Dyno in an EF!!! (erics99si)
If those #'s were measured in 1st gear then they will not be accurate. Dyno runs should be done in 4th gear and begin at around 2500rpm most of the time, this is due to the closer to 1-1 ratio so you can accuratly read the HP and TQ.
Old Oct 17, 2003 | 11:05 AM
RS_H22's Avatar
1st gear pull?
Old Oct 17, 2003 | 12:07 PM
King Tut33's Avatar
Default Re: My SIR II Dyno in an EF!!! (RS_H22)
That's gotsta be a typo. He probably meant "first dyno pull".
Old Oct 17, 2003 | 12:56 PM
no2psi's Avatar
Everything from 6500 and up looks way too rich. You might be able to lean it out and pick up some extra power, at the top end.
Old Oct 17, 2003 | 03:03 PM
bossman032's Avatar
Default Re: My SIR II Dyno in an EF!!! (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">That's gotsta be a typo. He probably meant "first dyno pull".</TD></TR></TABLE>
yea what he said. people have told me I can gain some HP and TQ with a VAFC.. how much anyone have any ideas?
Old Oct 17, 2003 | 04:14 PM
realfasthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">
yea what he said. people have told me I can gain some HP and TQ with a VAFC.. how much anyone have any ideas?</TD></TR></TABLE>
so what gear did you use?
and id hit up all the bolt ons first and then worry about engine management and tuning
dragonkx
Feb 26, 2022 08:11 AM
mombojombo
Jan 20, 2011 06:19 PM
Kuhniee
Mar 5, 2010 09:24 PM
Swapped_EG
Jan 10, 2005 03:05 PM
