trying to figure out my compression....
Old Oct 16, 2003 | 08:00 PM
patdemps's Avatar
Default trying to figure out my compression....
I have a 95 GSR.
I basically need to know how much the DPR stage 6 headwork raises your compression. I have Stage 6 headwork done on my GSR. I don't recall the amount of compression points it raised. I have ITR cams on my GSR and was looking into getting a Mugen Headgasket to raise the compression. I just wanted to get an ideal compression for the Camshafts (so im not undercamming or overcamming). I remember reading somewhere that its around 10:8:1-11:0:1 or something like that with ITR cams. I just need to figure out what I need to do to get my Compression in that area to maximize the power of my setup.
Thanks for any advice you guys can give me.
edit: if you need to know my setup or anything else then just let me know and ill provide the answer.
Old Oct 17, 2003 | 06:44 AM
patdemps's Avatar
Default Re: trying to figure out my compression.... (patdemps)
any advice out there?
Old Oct 17, 2003 | 08:03 PM
patdemps's Avatar
up for the night crew
Old Oct 17, 2003 | 08:17 PM
IN VTEC's Avatar
cc the head and do a little math.
Old Oct 18, 2003 | 11:51 AM
Ruby Civic's Avatar
http://www.c-speedracing.com (i think, do a search) and cc your combustion chamber(s)
if the block facing surface of the head is milled and that balanced the amount removed from the chamber then the cc should be 42.7
Old Oct 19, 2003 | 05:11 AM
patdemps's Avatar
Default Re: trying to figure out my compression.... (Ruby Civic)
wouldy you guys suggest a mugen headgasket or do you think ill bump up the compression too much for just ITR cams?
Old Oct 19, 2003 | 05:14 AM
IN VTEC's Avatar
It should be fine.
Old Oct 19, 2003 | 07:49 AM
Ruby Civic's Avatar
Default Re: trying to figure out my compression.... (IN VTEC)
in the case of portflow done heads the bowl work subtraction of metal about equals the amount taken of the deck surface facing the block so no loss of compression....if you take enough off of the deck you may be worried about valve-piston clearance with the bigger cams
negusjuda
Aug 24, 2010 09:37 AM
SantaAnaFerio
11
Dec 15, 2009 03:06 PM
realis9
Mar 5, 2007 10:22 PM
Kellindal
Mar 1, 2002 10:07 AM
Kellindal
Dec 22, 2001 07:38 PM
