Anyone know what's wrong with my headlight?
Old Sep 1, 2001 | 09:43 AM
IVANITR's Avatar
Default Anyone know what's wrong with my headlight?
my headlight wiring is like messed up or something. i noticed this recently, it's just making my right headlight go out sometimes, and in order to make it come back on i have to wiggle the socket that the bulb comes on. does anyone know what's wrong with it? does it need a new headlight, or is something wrong with my wiring? anyone help, id appreciate it. thanx.
Old Sep 1, 2001 | 09:46 AM
Chris's Avatar
Default Re: Anyone know what's wrong with my headlight? (IVANITR)
sounds like either loose wire, or the filament in the bulb is broken and temporarily "fuses" back together.
Go get a new bulb. If there still is a problem...then its the wiring.
Old Sep 1, 2001 | 09:48 AM
Jason's Avatar
try using your good, lefthand side bulb...if that works, then you know it's the wiring...
Old Sep 1, 2001 | 09:49 AM
yoshi234's Avatar
I shoot brides
prolly what Chris said, but you can always take it back to the dealer and warranty it
Old Sep 1, 2001 | 11:28 AM
IVANITR's Avatar
Default Re: Anyone know what's wrong with my headlight? (yoshi234)
okay you know what, i just took a better look at the sockets that attach onto the bulb right now, and the one on the right seems to be burnt, like the plastic is a burnt color and it's warped bigger than the opening should be. i still just need to wiggle the bulb around to work and both the bulbs work. so does that mean it's the socket that needs to be replaced or the wiring? and about the warranty work yoshi, how do i get that done?
Old Sep 1, 2001 | 07:13 PM
IVANITR's Avatar
yoshi you there, guess you out at the meet, heh, well try to respond if you get to this on time.
russ donnan
13
Jan 12, 2019 05:49 AM
Gamma Ray
Dec 23, 2009 07:02 PM
viet_tec
Dec 22, 2007 12:40 AM
