how do you fix g2 integ antenna
im having a problem i think
i just got my 93 rs this week
and i noticed that the antenna wouldnt go all the way down
it would go down until there is about 6inches left to go
can nebody help me with this problem
thanks
thanks
The problem with power antennas is that the slightest bend can prevent it from
going all the way down. the only solution is unplug the power to it when it is all the way up or down or buy a new one.
bent!! the best thing to do is extend it all the way and try to staighten all the kinks out as best you can...be careful not to make the problem worse!!
Hey redman...does your antenna make a grinding noise when you turn your radio on and off? if so, there are some little plastic gears inside it that are stripped out, they need to be replaced. Mine went out a few weeks ago. I'm looking into doing an S2000 type swap...something that won't break again...lemme know if you need any help or suggestions with fixing it.
I have a power antenna from a 94 GSR for sale. Let me know if you're interested... LeeChun@earthlink.net
It goes up/down smoothly, and I kept it well lubed..
