Hood Locks- Mr Gasket Vs. Jc Whitney Vs. JDM hondaparts.com
I did an extensive search on the topic and have the 3 brands to choose from.
JDM hp $39.99
JC Whitney $19.99
Mr Gasket $25-30
Is there really a big difference between these locks?
JDM hp $39.99
JC Whitney $19.99
Mr Gasket $25-30
yes there is.. .
Mr. Gasket
quality.
all I can tell you is this... don't get this expecting it to serve as hood pins. I have seen cases of where the CF/Fiberglass hood has popped up and opened on the freeway. It is advised that you use this with hood pins.
Mr. Gasket
quality.all I can tell you is this... don't get this expecting it to serve as hood pins. I have seen cases of where the CF/Fiberglass hood has popped up and opened on the freeway. It is advised that you use this with hood pins.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ByronC »</TD></TR><TR><TD CLASS="quote">yes there is.. .
Mr. Gasket
quality.
all I can tell you is this... don't get this expecting it to serve as hood pins. I have seen cases of where the CF/Fiberglass hood has popped up and opened on the freeway. It is advised that you use this with hood pins.</TD></TR></TABLE>
what? the person probably installed the hood locks wrong. they serve just as good as hood pins
Mr. Gasket
quality.all I can tell you is this... don't get this expecting it to serve as hood pins. I have seen cases of where the CF/Fiberglass hood has popped up and opened on the freeway. It is advised that you use this with hood pins.</TD></TR></TABLE>
eg4usdm
Apr 1, 2005 09:25 PM
275Performance
Feb 21, 2004 02:48 PM
